Yes in my opinion that is living space.Do you have to wire a foru season sun room to code such as outlets 6 foot from a door and every 12 twelve after etc.
Do you have to wire a four season sun room to code such as outlets 6 foot from a door and every 12 twelve after etc.
In Florida we call these rooms a Lanai. It is effectively a screened porch. We do not require the receptacles. Usually the one receptacle required on the outside building wall will be within the Lanai.
I think if it is not heated it is hard to consider it a room.
But keep a record of the coin toss for the inspector's reference, otherwise he might do his own flip with opposite result.I was referring to a porch. I don't see how it is a room if it is not conditioned space in some way. Even if it is just opening the door.
personally, I think a porch is a porch and a room is a room and if you cannot tell the difference you should flip a coin to determine if the porch is a room or not.
IMO if a space is climate controlled it is a room. If it isn't climate controlled, then it may or may not be a room.
The patio deck of a restaurant I go to is heated, no walls just a roof.
Room?
Heated how?The patio deck of a restaurant I go to is heated, no walls just a roof.
Room?
Heated how?
I agree that if you were in a moderate temp area you may not have heating or cooling. This "four seasons room" is definitely not (ordinarily) the same type of construction as the remainder of the home, often there is still original exterior grade doors or windows between this space and the remainder of the house. When do we draw the line between it being a porch or a habitable room of the dwelling it is attached to?Why does the presence of heat or cooling change things?
What if I live in a moderate temperature area and I do not need heating or cooling, does that mean my home has no rooms?
My first apartment was five rooms with the only heater located in the center room. Were the other four rooms 'not habitable'?
Not a room that 210.52 is concerned about because it is not a dwelling.The patio deck of a restaurant I go to is heated, no walls just a roof.
Room?
I wouldn't consider an area under a roof with no walls to be climate controlled. Climate somewhat offset, maybe.Heated how?
