david
- Pennsylvania
Why does the presence of heat or cooling change things?
What if I live in a moderate temperature area and I do not need heating or cooling, does that mean my home has no rooms?
My first apartment was five rooms with the only heater located in the center room. Were the other four rooms 'not habitable'?
I not sure if it needs to be habitable space for the rule to apply. I am not sure the space needs to be conditioned to be defined as a room a bathroom is not required to be conditioned space oddly enough; it still is defined as room. I think the rule looks at living space as the type of activity being done in these spaces. Are lamps, TV and other appliances generally (or regularly) being used in the space? The six ft rule is designed to address appliance cords.
