Motors? Or motor controls? Different books.Greetings everyone
is there any manual or book for understanding motor schematics / motor wiring diagrams?
i have actually dealt with them for the first time and find it a little bit difficult to grasp.any advice or suggestions on
how to master them?
Thanks
Fixed link...Not sure exactly what you are asking. Care to elaborate...
In the meantime, see if the following helps...
http://static.schneider-electric.us/docs/Machine Control/0140CT9201.pdf
What i meant was that i am dealing with Motor Schematics and wiring diagrams for the first time.
i was wondering if there is any document or manual that helps you to master motor schematics and
motor wiring diagrams.
or is it that you have to deal with as built drawings to learn it.
Thanks
If you want info on standard MOTOR connections, look at this. You can often get these as freebie giveaways at EASA member motor shops. I find them very handy to keep in the tool box.
You can buy one as well if you don't want to wait, Amazon charges about $7, I've seen them on Fleabay for less, but often they are old and not up to speed on code issues. The motor connection guides are going to be the same though.
This EASA shop publishes it on line, its just that if you print it out, it's big.
http://www.joliettech.com/3ph_motors_single_speed.htm
Motor control info:
http://literature.rockwellautomation.com/idc/groups/literature/documents/at/ic-at001_-en-p.pdf
