gas pipe on ceiling fixture
GoldDigger
Placerville, CA, USA
Retired PV System Designer
how you proceed when you find a gas pipe in the ceiling fixture.do you call a plumber or you remove it yourself?
I would say that depends on three things:
1. Are there electric wires coming in through the gas pipe? If so, go for it yourself.
2. Is the gas pipe apparently abandoned and open at the fixture? Go for it unless you get to a closed gas valve along the way or you are in an area with strong trade work restrictions.
3. Is the pipe capped off at the fixture and so conceivably may actually have a gas supply connected? Definitely consider getting a plumber in.
PetrosA
I ran into this in Boston changing a hanging light for my mom years ago. The old gas lines were "supposed" to be off, but they weren't. I wouldn't mess with this yourself. A lot of gas can pour out of a 3/8" line ;)
iwire
Massachusetts
Pretty much every house around Boston and there is nothing to mess with.
You change the fixture and leave the pipe as it was. :cool:
RICK NAPIER
New Jersey
These are pretty old lines running throughout the house. I would tell the owners to contact a plumber sometimes they can disconnect these lines leaving gas service to the appliances still in use.
Sierrasparky
USA
Electrician ,contractor
It's gas. Don't mess with it unless you are a licensed plumber. Have the owner call in a plumber. This needs to be dealt with properly.
A live gas line has no buisiness in a electrical box or fixture.
iwire
Massachusetts
I really don't think you understand just how common this is in some areas.
Entire neiborhoods with each room having a gas line in the center of the ceiling. Many are dead many are live. I always just worked around them.
Sierrasparky
USA
This maybe common. However I don't think a gas line is allowed in NON rated electrical fixture or outlet box. The line needs to disconnected from the supply. Someone will get hurt.
Considering how long most of them have been there with no more gas usage, I think statistics will indicate that risk is not very high. It may still be a good idea to remove them whenever possible, but probably is not such a danger anyone is mandating immediate removal of all that are still existing.
iwire
Massachusetts
They are not allowed in a box now, they were than and we are not required to change things just because the code changed.
That is up to the HO not me.
How?
How is a capped black iron pipe more dangerous than a gas stove, dryer, furnace that has open gas lines near open wiring?
PetrosA
Imagine a 19 year old me and a sawzall... I had cut many a gas pipe like that here in PA by then, but the one in my mom's place was the first live one I ever saw.
I remember they used to have a special threaded mount for the pancake.
