I'm finishing up a residential install on some Mitsubishi Mini Split units where the mfr spec calls for a 3 pole Leviton MS303-DS disconnect switch for each indoor unit (req'd by AHJ). I roughed in the 14/3 NM that supplies these units into deep plastic boxes, only to find out later (meaning after the drywall is finished) that the MS303-DS is an UNGROUNDED switch and has no ground terminal. I get it, most of these are used for motors in industrial applications in which the switch is housed in a metal enclosure. Art 404 requires the yoke on all snap switches to be grounded. Is there an exception I'm missing, or am I going to have to find a way to ground these (as in cutting out the plastic boxes to replace with old work metal ones)? I have a hard time understanding how these got their UL rating with no ground terminal. Mini-splits: always a PITA.
