- Massachusetts
Agree. Likely 10% wouldn't matter.
That really depends.
Sure the equipment will work but will the customer be happy?
Consider this, the customer has 5 amps of lighting on, works fine. Now the 26 amp hot water heater kicks on and the lights noticably dim. Water heater goes off, lights brighten.
Now this might not be a problem at all, or it could drive the customer nuts and then what?
Or the customer had an air compressor that kicks out the OLs instead of starting due to voltage drop at LRC.
My point here is I wire for no call backs.
