If the Home Builders Association gets their way NC will be writing their own codes, electrical, mechanical, plumbing, building, and fire. What was proposed at the last General Assembly was that NC writes their codes but it was tabled due to the opposition to this rule.
The DOI is not allowed to fight for our codes any longer so it is up to people like us to take up this fight. Write your political persons and express your opinions.
There was many there in support for the three year code cycles such as but not limited to NEMA, UL, Met, and many electrical contractor associations and others. The Home Builders Association is the strongest association in NC and has money to spend to get their way. I do not support them in any way. I was once a member but I never got even one contract by being a member so I dropped my membership. I also found that I could get my insurance a lot cheaper by doing some research than what they had promised to get me to join.
It is not only the codes that are being intruded on but also inspections. There are proposals to limit the number of inspections on any given job which will lead to inferior work being done and sold to the customer.
Based simply on the proposals by the HBA one would think that the only new construction being done in NC was housing. These proposals will not only affect the housing in NC but also all construction.
On a side note one of the proposals was to have the housing be on six year cycles but commercial and industrial on three year cycles. This would mean that contractors that work in both fields would need to keep up to date on two different codes as well as code officials doing inspections would need to know both codes. This will be nothing short of a cluster???.
