Inspect2020
I have never seen this before and was hoping for some help. Circuit tester in GFCI receptacle outlets tests normal with 2 yellow lights and when the GFCI is tripped with either the tester button on the tester or the one on the GFCI receptacle I get a single red light. The results are the same on all 6 GFCI receptacles in the house (mobile home) but the one GFCI receptacle outlet at the meter panel 20 feet from the house tests normal with two yellows when on and no lights when tripped.
Thanks in advance
Don
Thanks in advance
Don
