This is my first post, and am very thankful for all of the information here. I did a search for clarification, and couldn't find an answer, hence my question.
I ran into an interesting situation the other day, where I was required to have riser cable installed within a single story commercial building, per the AHJ. The cable installed (combination of cat5e {control} and 14-2 awg{speaker signal}) was run through pvc (sch 40) from various locations in a solid concrete slab and EMT through walls at ceiling height, with it's final destination stubbing out in an equipment rack. The rack is located in a small storage space above the main power for the building, non-plenum. The rack location did meet all of the requirements for working space, per the AHJ. The total height from slab to equipment rack was less than 11 feet and height from ceiling to rack was less than 6 feet (should that matter).
My question is, why would CMR be "required" since the space is not more than a single story (floor to floor), as i understand the code (800.179(B). I've yet to encounter this issue, so any clarification to help would be great.
Thanks in advance!
- Ray
Thanks in advance!
- Ray
