Mr Jimmy
New member
- Sacramento, Ca, USA
I installed a 6KW ground mount solar system. The microinverters do not require a neutral. The array is 400Ft from the main panel. I installed a ground rod at the array for bonding and grounding. The inspector wants a ground wire back to the main panel. Any suggestions on how to rectify, as is very difficult to pull 1/0 wire 400ft as trench is backfilled.
