hhhjr
- Monmouth NJ
I have a question for you all. I am the supervisor at a plant in NJ. Without warning our CO wanted XMAS lights and had our landscaper string XMAS lights throughout our property. Then they came to me and told me to get them wired up. Due to the size of the property and all the utilities that follow the road around our property, it is not just as simple as having a ditchwitch or vibatory plow come in and install some PVC and wire it up. A couple of years ago we switched to Led lighting and they are wired in at 277. My first thought was to rewire the lights for 120 and install a X-former and subpanel at the 480 panel. Well after investigating the lights they are stright up 277 with no option for 120 or 208. Ok so the wheels start spinning and i went out and picked up a half dozen .5 kva 480 to 120 xformers and mounted them on the pole. Mechanically bonded to the pole with bolts. I installed a 480 single phase recepticle in the handhole of the lighting post with a deep in use cover. Wired a peice of SO cord to the 480 volt side of the Xformer and coupled the transformer to a Dep bell box with a nipple. I installed a GFI in it. I used a deep box so I could mount a fuse holder inside of it so I could protect the transformer from overloading. The XMAS lights are of the Led variety and draw 8 watts a set at 120 volts. I spaced out the transformers so that there are about 30 sets on each one equalling some where around 300 watts. I installed a ground bar inside of the transformer which is built in a raintight 3r enclosure and bonded X2 of the secondary to the ground bar along with the ground wire from the 480 plug and the ground wire to the GFI. Lastly the panel that feeds the parking lot lights are fed by a ground fault intrupter. So is this a legit installation? If it is only used for these XMAS lights and remove the transformers and lock the Bell boxes to keep unauthorized hands out of it would it be acceptable? Any thoughts?
