A CE marking requires that I do not use any wire nuts. Instead, I should use IEC rated connectors. Can anyone please recommend some IEC rated connectors that I can use instead of wire nuts?
What IEC standard?A CE marking requires that I do not use any wire nuts. Instead, I should use IEC rated connectors. Can anyone please recommend some IEC rated connectors that I can use instead of wire nuts?
https://www.google.com/search?q=CE+...GuGqyAHK-oCoDg&ved=0CFcQsAQ&biw=1005&bih=1072What at is the CE marking?
What IEC standard?
The problem I am having is Compressors that do not have long enough lead wires to reach the equipment subpanel. I am having to splice the lead wires for extra length. I have pressure switches that are the same. They come with small leads and need to be wire nutted with scruits. I am trying to find something inexpensive and meets the aformentioned IEC standar Besoeker mentioned..
Would these "coolsplice" connectors be acceptable?
http://www.compel.ru/wordpress/wp-content/uploads/2013/10/te_COOL_spec.pdf
Hmmm... I would think a good ol' insulated compression butt splice connector would be better than an IDC splice connector.I think so.
[/QUOTE]I like their design and the associated benefits... as published and reported. But I've not had occasion to use any. Not that I couldn't or wouldn't. Simply has not been at my discretion in most cases. In situations where I could have used them, I would have had to order them vs. using what was already on hand or readily available.If someone could please comment on these Wago connectors I would appreciate it. I would like to use them inplace of wire nuts, hoping that they do not invalidate a CE Marking.
They carry an ENEC safety approval.
http://www.wago.us/2631.htm
If anyone could recommend anything else to use, I would appreciate that as well.
I am trying to not have to use a din rail. These connections are all made off of my sub panel where all of the din rail is located. Alltech looks interesting, we generally use Phoenix Contact but I will have a look at their offerings.
I believe it is the lever technology of the Wago blocks plus the fact they carry the ENEC label that goes a long ways toward being able to defend their use in a technical file for CE marked products.
