electro7
- Northern CA, US
- Electrician, Solar and Electrical Contractor
Hi,
I need some help here. I have installed a battery back-up system with Sunny Islands and Sunny Boy's. Instead of pulling specific circuits to the critical load panel I installed an automatic transfer switch so that when utility power goes out it would transfer the load to the critical load panel. When I went to test the system by turning off the main breaker the transfer switch never transferred from utility to the critical load (or the terminals where the generator wires would normally land). There was voltage on the critical load side of the transfer switch where normally the generator wires hook up. I am using a Generac 100 amp transfer switch. Am I missing some control wiring? Or are the Generac transfer switches only meant for generators? If so is there a way around it?
Thanks for your help!
