Hi guys, I am a little rusty on some things. I was out of the trade for awhile.
I am doing a residential job and have a 3 ton air handler with a 10 kw heat strip to run the circuits to.
Now, this is a Chinese made unit (Haier) and the instructions are indicative that the person who wrote the manual was not a native English language speaker. The diagram is crazy and everything else. I think it was a mistake getting this unit ( I am installing it in a rental house I own). Buttt..
Anyway.....The air handler states on the label max 15 amp over current protection (at *230 volts - has anyone else seen things labeled for 230?)- it draws 2.5 min running ampacity. The heat strips calls for MOPD 60A and MCA 52.9A 75deg.
My question...I know we have to follow the manufactures specs..
When I install the heat strip (hvac work is not my thing) and its circuit I am pretty sure that becomes the circuit that powers the air handler and of course heat strips, despite the fact it says maximum ocp of 15 amps. Is this right or am I supposed to run a separate 15 amp circuit and a 60 amp circuit??
And please only answer if you have installed air handlers with heat strips.
Thanks,
Hank
Thanks,
Hank
