Power to a subpanel which feeds a fuel Island.
The 1p breakers in the subpanel are Switched Neutral.
The 2p breakers are standard.
This panel is being fed from a 2 pole 100 amp shunt trip breaker in the MDP.
An Emergency Power Off button located outside to activate the Shunt Trip.
Authority is siting this is a violation and the neural must be run through a contactor to physically disconnect the neutral to the Subpanel and the Shunt Trip is a violations since it does not disconnect the Neutral to the Fuel Panel.
Is this correct?
Is this correct?
