GeorgeKoehl
- Washington IL
Does the NEC prohibit splicing service wires or is that a poco rule?
At my condo there is a two gang meter base that needs to be replaced, the service comes off the transformer underground DB and under a patio slab to the meter base. The replacement base is larger and the lugs are in a different place that will cause the existing service wire to too short. The meter base is already low to the ground so I do not think lowing the base would-be an option. Any thoughts on how the meter base could be replaced without digging up back to the transformer?
