full voltage Non Reversing motor starter and full voltage reversing motor starter
Marcel
New member
Edmonton
What is the differences between full voltage Non-Reversing motor starter and full voltage reversing motor starter and their applications
augie47
Tennessee
Just a wild guess, but one is used when you wish the motor to operate in one direction, the other when you wish to be able to run the motor in either of two directions :)
meternerd
Athol, ID
retired water & electric utility electrician, meter/relay tech
Full Voltage Non Reversing = 1 motor contactor and 1 overload relay.
Full Voltage Reversing = 2 contactors and 1 overload relay.
Also, the two starters will have a mechanical interlock that prevents both from being closed at the same time. At least all I've seen do. I know that's obvious, but thought I'd mention it anyway.
