delfadelfa
- Cincinnati, OH
I got a call about a tenant feeling current when taking a shower.  It's a 3rd floor apartment in a 100 year old house.  Two months ago the plumbers removed the cast iron stack in the building because it was leaking all over the place.
I tested voltage between the brass tub drain and the faucet - 45 volts.
I tested voltage between the sink chrome stopper, which has a PVC trap, and the faucet - 85 volts.
I found an access panel where I could see some of the remaining cast iron drain pipe and the hot and cold water lines. I tested the voltage between the cast iron and the water lines - 101 volts. I had my arm against the the cast iron drain when I was testing it and could feel a tingle when I touched the water lines.
I ground clamped the hot and cold water lines, and cast iron drain lines and ran #6 copper between them.
Tested faucet to drain in the sink and tub, now the voltage is zero.
Is there anything else I should do or does this sound like I solved the problem?
Do you think replacing the cast iron with PVC caused the problem?
In the sink drain that had a PVC trap I guess there was enough water or slime in the pipe to conduct the voltage from the cast iron to the chrome stopper.
