- Lockport, IL
- Semi-Retired Electrical Engineer
Can anyone think of a code article that explicitly calls for a circuit to supply one outlet and no others? I don?t mean such things as SABCs or the circuits that supply bathroom receptacles. These have restrictions about connecting other outlets, but I can put two or more kitchen countertop receptacles on the same circuit. The rule does not say, ?one circuit, one outlet.? I also do not mean cases in which an item of equipment draws so much current that trying to put two of them on the same circuit would exceed the circuit?s limit, so that we are essentially limited to only putting the one outlet on the circuit. The NEC has a reasonably clear definition of ?individual branch circuit,? but I know of no cases in which the NEC requires something to be on an individual branch circuit. Any thoughts?
