I travel for my work and need a good compact portable wire pulling rack.
What works best?
Thanks
I'm casting another vote for the Rack-a-tiers. I haven't found anything I like better for small and medium size reels.I travel for my work and need a good compact portable wire pulling rack.
What works best?
Thanks
What works best?
Thanks
But I also have a set of Rack-a-tiers 11455 but the only thing I don't like is you have to load the wire each time you use them and they work
better if you can screw them down to the floor or a piece of wood to keep them from moving when the reals get close to empty but it is nice
that they will take many different sizes of reels so its a one size for all and they are very compact and light.
well, then, screw them down to the floor..... as a courtesy to the customer, i try
to put the anchors in an area that will be covered by a rug.
if its concrete, i use plastic anchors... if you use drop in wedge anchors, it makes
bumps under the carpet that most customers find unattractive.
but if it's just hardwood floors, drywall screws work fine.
