I'm working with an automotive battery system that is advertised to have a voltage range of 432V and 593V between 0% and 100% SOC. The battery system has a protection parameter in place which disconnects the batteries if overcharged and/or the string voltage exceeds 602V. Would using a standard 600VDC rated wire satisfy NEC requirements given the intention to never overcharge the system? Or would I have to consider that the voltage may exceed 600V and use a 1000VDC rated cable?
