Table 450.3(B) states that I can raise the fuse on a transformer that has less than 9A primary current from 167% to 250% if the secondary is fused at 125% of the secondary current.
If the transformer has is center tapped (120V/240V) and there are loads across the 120V and across the 240V, how is the secondary fuse size calculated?
Am I supposed to use the secondary at 120V or the secondary at 240V or do I have to consider both? I know if there are multiple fuses then the sum is considered in the 125% calculation, but I do not know how to handle center tapped transformers with multiple secondary voltages.
