Castrovinci
- NJ
All,
I am running an outdoor 100A 120v Three phase sub panel for some truck heaters. I need to do an overhead run of about 200'. I am going back and forth on cost and options of stepping it up to 480 and step back down or just upsizing the wire for voltage drop.
Here is my issue....
Can i run triplex for the subpanel and just run two ground rods outside or do I have to run a quadplex so I also have a ground and neutral? If I can run the triplex I saw somewhere in the forum someones state would not allow the grounded and grounding conductor to be one even though it appeared NEC allows it for a seperate building. I am thinking this can be treated as a seperate building even thought the panel is going to mount on a telephone pole outside in the yard and its not in a building?
If I use a step up and then step back down I can get away with the triplex since my high voltage side does not require a neutral? Downside is a lot more money and labor involved. I am hoping the first option is possible.
