Hi All,
The elec contractor was installing an oven and down the road it caused a fire when the aluminum wire from the panel circuit was spliced inside the jbox with a copper wire from the oven. Is there a code section that prohibits this??
(The install was in 2012, so I assume the code used was 2008, but it was in CA so maybe it was 2008? I know CA is longer in accepting newer NEC code versions).
P.S.,
The install manual specifically says to use a 50A circuit and they used a 40A. I don't see how this could cause the wire to overheat since the breaker would, if anything, trip sooner.
Thank you in advance.
P.S.,
