JimMacD
- Cromwell, CT
I'm designing a 120VAC control panel that contains a 1500VA, 120V UPS (Allen Bradley 1609-D). I am providing a flange-mounted disconnect handle to switch the main MCCB and remove incoming power from the panel, however, this alone will not disconnect the UPS output (it will be on battery power) - thus the controls circuit stays live. My plan was to have a AUX contact from the MCCB switch the UPS systems "Remote ON/OFF" dry contact (Pins 7/8), which will turn off the output of the UPS system. Will this comply with NFPA79?<br><br>Thank you for the help.
