fmtjfw
- Fairmont, WV, USA
This problem was solved decades ago.
Use a flanged plug of the IEC 60320 C-13 form. (look on the back of almost any desktop computer for instance.) Then either provide the cord with the proper local plug on one end and the C-13 connector on the other or let the customer buy it locally.
Decades ago computer manufacturers who had/wanted a world market used the C-13 connector mounted in their equipment and supplied the country specific code. If you want to cover the international market there are about a dozen "mains" plugs in use. Cords with these mains plugs and C-13 outlets are extremely common.
If you want to work "anywhere" this physical solution -- together with a voltage (100-230V) and frequency (50-60Hz) agnostic power supply is just the ticket.
