With room to run the wires through one of the arches in the base, which you could not do with a standard plumbing mounting flange and a nipple.You can screw it to the structure above a fixture and hang a 3/8" fixture stem on it.
That would be installed in the outlet box. The four holes in the fixture hickey line up with the holes in the box and you run the screws through at least two of the holes into the structure to support the hickey and the box. There is room enough for single conductor fixture wires to enter via the notches between the feet of the hickey.I don't believe that particular fitting is intended for running wires through it... at least not using single conductor wiring methods, as there doesn't appear to be any means to make connection to the underside.
Yes, except in places where a hickey meant only the C or O shaped double female fitting and this item would be called a crowfoot instead. Take a look at the range of images which match the term.Would this item be called a hickey?
So the conduit goes through the box cover?That would be installed in the outlet box. The four holes in the fixture hickey line up with the holes in the box and you run the screws through at least two of the holes into the structure to support the hickey and the box. There is room enough for single conductor fixture wires to enter via the notches between the feet of the hickey.
put one together w/scrap parts and take picThe 3/8" fixture stem goes on to the fitting in the box and a canopy covers the box.So the conduit goes through the box cover?
Where lighting fixtures and such are hung from a box using conduit as its support, I typically see the ball-type swivel covers.
Well I haven't done any residential work (other than my own house) in over 25 years... and even then, never saw one of those. Haven't seen 'em used in commercial either.The 3/8" fixture stem goes on to the fitting in the box and a canopy covers the box.
I have never seen the swivels other than in industrial occupancies.
Old commercial is the only place I have ever seen them in use.Well I haven't done any residential work (other than my own house) in over 25 years... and even then, never saw one of those. Haven't seen 'em used in commercial either.
Light industrial too. In the late 70s, I worked for a company in the Bay Area specializing it retrofitting the old Mogul base 200-300W incandescent pendant lamps in warehouses and small machine shops with fluorescent fixtures to save energy and improve lighting. Most of those old hanging pendants were connected to crow foot hubs like this, screwed into an octagon ceiling box.Old commercial is the only place I have ever seen them in use.
The hanger box cover pictured is the type I usually see... though that one appears to have an overabundance of attachment bolts. :blink:
