AccessWorkBoots
- NJ
I'm not supplying the gen, just sizing. The rest is up to the demo company
			I would not go with less than a 150kVA-rated genset. I'll leave it to you to determine whether that is large enough...I'm not supplying the gen, just sizing. The rest is up to the demo company
Padded for unbalance and inrush guestimates.... How did determine the 150 kw? And why do the generator suppliers always change the kw to kva? kw is true power and that's what I need and kva is what the utility is charging me for ?
P=Tw. Use SI and you don't need conversion factors....I'll convince you guys one day to get in step with the rest of the world...........Generator KW is rated on how much power the driver can deliver. Power is Torque X RPM (X a constant to make the units match up)
At 1pf, the driver will run out of horsepower before the alternator overheats
At .7pf (lagging) the alternator will overhat before the driver runs out of Hp.
I'll feel it was important when you guys and girls think it is important - :?:? huh?? yes we do.P=Tw. Use SI and you don't need conversion factors....I'll convince you guys one day to get in step with the rest of the world...........
Yes, that's true. In pubs. But wine by the ml.Nope - you still sell beer is pints.
Buy beer in any store and the primary and often the only measure is ml.
We also do speed, distance and speed limits and fuel consumption in miles per hour, miles per gallon.
Yet fuel station forecourts sell fuel in litres.
Daft I know.
For engineering, everything is SI.
There is some sanity where it matters.
But on anything remotely official your weight is in kg.You sure. The women weigh themselves in "stones"hmy: Ooookaayyy
Yes, you are correct there are a lot of strange units here:
Statute miles
nautical miles
kips
ft-lb torque
lb-ft energy
BTUs
ounces liquid
ounces weight (force)
ounces troy
Grains (weight measure gunpowder for reloading, Bullet weight for reloading)
And if one divides BTU by KW the answer is in hours (huh??)
231 in^3 in a gallon which means a pint is 28.9 in^3
The cooks are using teaspoon, tablespoon, cups.
We have had a lot of what you might consider strange or not so strange units here.But we got barbecued ribs and tex-mex chile. Might be worth holding on to the screwy units just for those two.
If you assume firkins rather than firkens, then yes it can be quantified depending on which firkin measure you take as a firkin measure.Well, A is pretty standard and "obvious"
Gentlepeople...
"FpF" or Firkins-per-Fortnight" was the outut of an LNG-to-Gas plant in Italy! The Brit-gineers in our Global startup team, representing 11-nations, came up with it during a 4-year startup delay! The firkin-unit was related to butter production!
"AbS" or Aluminum-Ball-Seconds was a measurement used by Lab-Techs of Celanese Plastics Company, to measure the viscosity of melted cellophane!
"TbB" or Tennis-Ball-Bounces was a dimensional unit used in the LNG-to-Gas plant (above) to monitor the leak-rate in a cryogenic heat-exchanger's perlite filled "cold-box" enclosure. It consisted of welding an appropriately sized close-nipple and gate-valve to the enclosure, plugging the outlet with a tennis ball, and then count the number of bounces the ball took when the valve was quickly opened. The plant was shutdown when count reached 11-bounces! Oh, yes the count was made and officialy recorded every shift!
Another unit concocted in the same gas plant was "MTBF" for Mean-Time-Before-Flare!
Finally, let me know if anyone is interested in a very unsual Synchronizing scheme!!
Phil
