iceworm
- North of the 65 parallel
- EE (Field - as little design as possible)
Or use the described Meltric or other pin-and-sleeve connector that can be used with FMC or LFMC instead of cord?
Maybe -
If it is money: Still put in a disconnect. But that is just a guess that a low dollar 3pole disconnect is cheaper than a pin and sleeve connector and way cheaper than the described Meltric.
If it is not the money: Still put in the disconnect.
However I do subscribe to the tenent that, "Screwing around to save a buck -- rarely ever saves a buck."
I know - screwy engineers. What are you going to do?
ice
