fmtjfw
- Fairmont, WV, USA
What size receptacles can be used on a 120V 20A circuit? (two answers)
Also code references?
The selection of the answers will be based on the type of receptacle used. The type is not specified in the question.
Actually it is not a simple code question...there is not enough information to make it a simple code question. That is the problem when dealing with the NEC, and especially in writing NEC questions, you really need all of the details to arrive at the correct code answer.Huh? It's a simple code question, with a simple answer.
But, 20A and 30A, 120 volt are also possible answers.You are right.
However. if I had been taking the test and saw that two answers were required, the two answers I would have filled in would have been 15A & 20A 120V. If there was one answer, there would have been ambiguity.
I found that to be so true. Once, when serving as president of the local IAEI, one of my tasks was preparing Code questions. Mr. John Minick, the Chairman of CMP1 sat in on one of our meetings and managed to slaughter my supposedly well thought out simple questions![]()
Suggest making thread titles slightly to notably different on the front end. You have at least four current threads that appear exactly the same in a thread list. I have to rely on the content pop-up to distinguish between them..... Keep it up, I'm learning and will produce a better contest next year...
