JJWalecka
- New England
What brand of work gloves do you use during the real cold days?
Ditto on that. Your replies could easily have been what I would have said.... You won't find one glove, no matter the brand, that will work in every situation.
Was thinking about trying these battery heated glove liners under work gloves.
http://www.ventureheat.com/p-287-battery-heated-city-collection-glove-liners.aspx
I spent two weeks in a negative ten degree freezer, wish i had a pair then!
Has anyone tried to work with any type of battery heated gloves?
http://www.harborfreight.com/mechanics-gloves-large-93640.html
with these as liners for unusually cold days
http://ilbob.blogspot.com/2012/11/rugged-wear-magic-gloves.html
I am amazed at how much warmer my hands are with just the mechanics gloves on. they are not insulated so I expected they would not work very well but they work a lot better than I expected.
i used to wear a pair of these in the winter, but the HF gloves are just as warm so I wear them now instead as the HF gloves make it a lot easier to actually do anything with the gloves on.
http://ilbob.blogspot.com/2011/12/farm-and-fleet-ruff-and-tuff-gloves.html
You can try putting heat packs in the backs of any glove you are comfortable working in. I used to do this for ice racing or any cold weather motorcycle stuff. The thin skin and blood vessels on the backs of your hand pick up the hot packs pretty good.
Hot hands or anything like it are ok. Gets expensive, but if you have to work in the wet and wear thin gloves so you can handle small parts it helps.
You can also try jet ski gloves ( neoprene ) They tear up easy so keep that in mind.
I usually just wear thin gloves ( some kind of nylonish polystuff ) from ace hardware and live with getting a little cold these days.
Today it was cold enough my phone kept powering down while it was in my jeans pocket.
