SkillsUSA preliminary contest Industral Motors Controls Written test Q6
Learn the NEC with Mike Holt now!
  • A
    Votes: 0 0.0%
  • TH
    Votes: 0 0.0%
  • RH
    Votes: 0 0.0%
  • THHN
    Votes: 0 0.0%
  • Total voters
    7
Nobody's going to ding me on type A insulation?
Why ding you ? You can list any letter you want as a POSSIBLE answer.
If they don't understand the correct answer or know where to look, "A" is as probable as "C" :D
My Answer
My Answer
E
(6) Which wire insulations types can be used in wet locations?
310.10(C) lists the insulation types THWN-2 is the only one in the list. [type A is asbestos]
Code Ref:
310.10(C)
Index:
Wet Locations ? Conductor, types
"E"as in fifth answer (A,B,C,D,E):D
I know I was just expressing why and giving the art. Hope Mike is okay with this chart being here
ry%3D480
I did and this is what came up for UF-B from this site. http://www.cmewire.com/catalog/building/20-BWX-06-UFB.pdf
Service Wire Co.
C(UL) listed Single Conductor Type UF/Type TWU is suitable
for use as Sprinkler Irrigation Control Wire for general purpose
lighting and power. Construction provides solid or stranded soft
annealed copper conductor insulated with PVC that provides
excellent abrasion, acid, chemical, oil and moisture resistance.
? UL listed Type UF 600 Volt (#14 thru 4/0 AWG)
? C(UL) Listed Type TWU 600 Volt (#14 thru 4/0 AWG)
TWU is c(UL) and Canada only
Not sure what your point is. I showed you single conductor is dual rated thhn/thhw and you quote something from Canada????:?
Nope, the wire I quoted is made in USA and is dual rated US and Canada, as is almost all wire produced in North American.
Look at a chunk of #12 THHN /T90/MTW -- you see THHN US; T90 CDN; Machine tool wire
The wire has a W in it-- Now there may be some company that makes UF single conductor and only calls it UF- I don't know but many clearly use the W
