Fulthrotl
~Autocorrect is My Worst Enema.~
- E
It costs too much and it is too difficult to install rails, but there is lots of time and money to shim and force the equipment into some kind of 'tolerable' alignment.
You should not need a pry bar to get a door to open or close.
Yes some of it is marginal manufacturing, but a lot of it is equipment not being level and true.
i'm currently getting a housekeeping pad ready to pour for switchgear, and was thinking about this....
i have the luxury of not having to pour the pad until the gear is on site, and i can verify actual measurements
of conduit windows, etc.
i was thinking of strut embedments for the anchor bolts. this being california, there is a seismic kit to put on
as well, but i'm thinking the short strut embedments like the sprinkies use for hangers, the serrated stuff
with ears on the side of the strut to lock it in. put two 20' ribbons the length of the pad, and drill and anchor
HV gear, 225kva xfmr, and LV gear with the whole thing....
as far as level goes, that form will be within 1/16", so as long as the concrete is floated well, it should be
flat. the strut embedments will be rail straight and level, so if they are proud a bit of the surface, all should
end up straight.....
