Bonding Galvanized Steel
fifty60
USA
Any tips for bonding Galvanized steel? How do I remove the layer of zinc oxide? Whats the best way to remove the zinc oxide?
dereckbc
Plano, TX
Use two-hole compression connectors with self tapping screws and star lock washers. Use a wire brush wheel on drill motor to prep the area, and use a oxidant inhibitor on mating surfaces like Sanchem No-Ox-ID A Special. The stuff will last 50 years even with sea salt spray exposure (Golden Gate Bridge) . Water ,Bridge, POCO and Telco utilities demand it to be used. Really good stuff and cheap.
tom baker
First Chief Moderator
Dereck, what about Copper Shield or Penatrotx E. Both are copper compounds in oil. I use this on electrical connections and threads.
Its messy though, and "gets home before you do"
