Photocell controlled light
K
ke4vbg
Guest
Hello
I have a light on my garage that I connected a photocell to so it would work from dawn to dusk. The photocell is one off of a mercury vapor light fixture. The light operates fine. I use a 100w incandescent bulb in it. My problem is that the bulb will only last about 3 weeks before it shoots. I have tried different wattage bulbs with the same results. I cannot figure what is causing such a short bulb life. Any thoughts would be appreciated.
Thanks
Doug
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
