ptevendale
- St. Thomas, Virgin Islands
Hi. Though this is my first post, I have had so many questions answered though this forum.
I have a 3-phase, 208v, 100kW solar pv system. I am installing 2 - 10kW, 6 - 11.4kW and 1 - 15kW. I am planning on installing 2 - 200amp panel boards and use a screwed down back feed breaker for each inverter. Then have 3/0 conductors from each panel board to a 400 amp entrance rated disconnect. And from my solar disconnect run 3 pairs of 3/0 to the load side of the building main 400 amp disconnect using 3 -4 port taps (Where there is a pair of 3/0 for each phase leg). Does this interfere with the 6 disconnect rule?
Thanks for any help!
