just the cowboy
Inactive, Email Never Verified
- newburgh,ny
I want to check if a ground is breaking down.
I was called out to a production line; and the mechanic said he thought he got a slight shock from a heat tunnel. I read from machine to machine (they are on casters) and got 150vac. I thought ok I have a bad heat element and ungrounded machine.
I read resistance from machine to machine 1 ohm, they are on different circuits but from the same panel. Took a Wiggins tester (clack type) and tested and did not read any voltage. Tried a current reading on 10a scale no reading it would have to be under .01 amps (lower scales on meter needs fuse). Don?t know how I could read 150vac between two machines with 1 ohm only between them.
Came back next day and went to take a current reading with another meter and all was OK no voltage or current that should not be there.
My real question is can I Megger the grounds from machine feed to machine feed with them unplugged and not screw up anything else that is fed from this panel. I can?t think how the megger test voltage would get out to anything it should only go wire to wire and out to ground before getting to anything else. The reason for this test is to see if my ground may be weak.
