I have a small commercial space with a handicap bath and a regular bath, just a toilet and sink. The ceiling is exposed concrete. The owner bought two ductless fans. Are these acceptable, are fans even required? Also the last HC bath I did the inspector wanted an emergency light in there so I put one in this bath but is that required? Thanks
Both the need for the fan and the need for an emergency light are not NEC issues, they would be issues from other building codes.
In dwelling bathrooms many people think an exhaust fan is needed for removing stink bombs, reality is they may help with that concern, but they are really intended for removing humidity from showers and baths. I honestly don't know why they would need to be required for a bath with no tub or shower in any occupancy other than if desired for removing effects of stink bombs, if the bomb is not removed the fan really isn't going to get rid of the effects.
Ductless fans? Why not make people bring in their own pocket sized battery operated personal fan? It will do about the same thing, which is stir the air a little, plus it may actually provide more direct cooling effects to the user if they could use cooling off:roll:
The only ductless fan that is worth anything IMO is one with electronic air cleaner cells, but you do have to clean the cells and any other filters on a regular basis, and I have never seen one in a bathroom either. With most places not allowing smoking inside anymore even those are becoming less popular.
