Garysparky
 - Cascade, WI
Here is the code question of the day..................................I  was a construction electrician for 12 years then moved into a plant setting.  I opened a 120v respectable and there was a yellow.  I assumed it was 277/480v system.  I was wrong.  Does the code tell you what color wires to run with 120/208v, 120/240v, 277/480v systems.  We have all 3 systems in our plant.  I come close to the answer in article 210 but cant find where it says(if it says) what color wires to use with different voltages.
