mkgrady
- Massachusetts
I can't figure this out. I needed to add a light in my attached garage in the ceiling. No easy place to pick up a circuit so I went to the heat detector. One of the two detectors has only a 14-2 NM connected, so I wondered how it can signal the smokes in the rest of the house. The other one has two 14-2 NM's connected. I don't understand why this house built in 1997 doesn't have the typical 14-3 NM run to every smoke or heat detector, but it gets worse.
Voltage to the heat detector is 120 hot to egc. Voltage on white wire is 120 volts to egc. I looked at the other heat detector and found one of the two whites disconnected. Thinking it just came loose during installation I reconnected it. As expected I still did not get 120 volts from hot to white wire.
It appears the HD's are wired like a switch leg (no neutral present) where both sides of the switch are hot when the switch is closed. I can't make any sense out of this. I can't imagine how they can even function or figure out a way to test them as they do not appear to have a test switch.
