I am trying to determine whether or not I can use a UL508 Motor disconnect switch as a line of sight disconnect switch on my equipment. The switch has the correct IEC ratings for me to do just that in Europe (IEC-947-1 and IEC-947-3). But for the US, it is only UL-508 listed.
The UL-508 switch is marked "Suitable as Motor Disconnect", so It may work under NEC 430.109 (A)(6). My equipment has a combination of heaters, compressors, and an isolation transformer for control circuitry.
Would using the UL-508 listed switch imply that the end user would have to supply the UL-98 service disconnect? Can I only use the UL-508 listed switch internal of the equipment downstream of a UL-98 or UL489 listed component?
These smaller disconnect switches are used a lot in Europe, but I am not sure if the UL-508 listing forbids me from using it here in the States as a line of sight disconnect for my equipment.
