streetneons
- Florida
So I am just trying to figure this all out, main disconnect is on one side of the house, then on the other side of the house I have the panel in the garage. Two hot, one neutral, one ground coming in. Two ground bus bars, one has the ground wire, two neutral bus bars, one has the wire. All four busses have branch wires going to them. So if this panel is basically acting as a sub-panel since the disconnect is by the POCO meter, and no disconnect in the panel, and from what I have learned the busses need to be floating busses, how does the one ground bar, and the one neutral bar work if they do not have the main wiring going to them, and no tie bar to say tie ground and ground. I am just confused on the two busses without main wires going to them how they would work? And is it okay that the disconnect is outside and not withing sight of the panel in the garage with so many breakers. Thank you in advance for the info and help.
