I am wiring a house that will be fed from a 200 amp meter main out on a pole about 50 feet
from the house. The meter main only has a 125 amp in it to feed the house power with. My question is can I still install a 200 amp main breaker panel and basically just use the 200 amp breaker as a disconnect since the wire is protected by a 125 amp breaker at the pole? Or would I be better off Unbolting the 200 amp main off the bus and installing a 125 amp breaker with a lockdown kit? I will be running 2/0 aluminum wire for feeders.
The house is tiny but has lots of two pole circuits so I need a fairly big panel to avoid having to twin anything. Especially since I can't twin down the arc fault breakers.
