jetlag
- Eatonton, Georgia
Hi all , on residential we are allowed in Georgia to use PVC conduit on
a service entrance as long as the service drop is not attached to it as
is the case when the weather ends on the side of the house and the
service drop is fastened to the structure. Of course if the service mast
goes through and above the roof to support the service drop it has to
be rigid conduit. My question is if I use a 10 ft. joint of 2" ridged to go
through the roof with 3 ft. above the roof and the other 7 ft. fastened
to the outside wall , is there any thing wrong with changing over to
PVC conduit from that point on to the outside disconnect ? I have to
do 2, 45 degree turns to get against the basement wall since the
rooms above are cantilevered out 15" .This will be much easier with
PVC. I remember in the code you can not have a joint coupling in the
mast or for a certain distance below the roof penetration , I believe that is 3 or 4 ft.
I don't see why you couldn't change to PVC below that point.
