Investigate.Laws
- Meridian, Idaho, USA
Many manufacturers today offer interface baluns for classroom pan/tilt/zoom video cameras. Some of these interface baluns feature HDMI, RS-232 control and camera power ports. So one would plug a typical PTZ camera's RS-232, HDMI and power into the ports on one side of the balun #1, which would be secured near the location of the camera itself. Then, presumably, one would plug one end of a long, plenum-rated CAT5e cable into the CAT5e port on the that same balun and the single CAT5e cable would simultaneously convey 1) video, 2) control via RS-232 and 3) power to the balun #2 located in a control room located on the other side of the classroom. This single CAT5e cable would presumably run through conduit in the wall from the camera and then up over the drop ceiling tiles (via appropriate conveyance) and then down a conduit inside of the control room wall and then into the control room to the balun #2. (Balun #2 would be plugged into a typical wall outlet, which would be the source of the power to the camera.) It would be a point-to-point connection. An example of this type of balun is the Vaddio OneLINK for Cisco PrecisionHD 1080p 12x Cameras.
The idea sounds great. Cables are minimized.
But it's not clear in my mind how a flexible, CAT5e cable for power is any different (as far as code requirements are concerned) than a flexible extension power cord, which presumably would be illegal if it were running above a commercial ceiling grid.
Am I explaining my confusion with sufficient clarity? If so, can one of you kind souls please enlighten me?
