brycenesbitt
- United States
I've inspected a high mountain property with a Siemens Pyrotronics System 3 alarm installed in 1977, that's taken some lightning damage, but keeps on ticking. The manager reports that during storms the thing sometimes goes crazy. I'm aware the detector loops could be the cause, but here I'm talking just about the input power part of the equation:
My first thought is to recommend surge suppression, a surge/filter unit, or perhaps an online double converting UPS. The panel already has a 24V DC battery backup that switches in via relay: the goal here is protection and power conditioning not backup.
Are there any special concerns, or code concerns, with mounting units within the locked FACP cabinet?
My sense is that an outlet in the cabinet or use a commodity ups won't fly... is this sense correct?
In the photo blue is presumably ground. White is neutral. Black and red are labeled main and trouble power at 3A and 1A respectively. The feed is from a 20A two-pole breaker, dedicated. I failed to make note of the vendor of that panel and only have a photo of the inside of the door. Budget is a few hundred tops.
The surge suppressor world seems filled with snake oil salespeople: what's solid tested and reliable?
