Go in the attic and tap off a different circuit
Ahh, but now you have modified the circuit and it may now be required to be AFCId
The bath shouldn't be on an AFCI anyway.:happyno:
I would also try and not have any outside outlets on one either.
To Action Dave...
Such devices should be hated and resisted tooth and nail
The next thing is the Driving Forces behind this kind of " Tek " need to be brought out into the light and the open so everyone can see that they are not about judicious administration but rather " control " and some other things that are far worse.
The Forces that are moving this kind of thing forward on a fast track should not be " allowed."
Also the idea that Engineering is there to make up for a lack of personal respmosibility or " common sense " in the general population needs to be done away with in short order.
The public education system makes people stupider by design.
There has been a major devolution of technology going on for over 30 years, especially with respect to solid state devices which are
Unstable by nature
Have an unacceptable failure rate
Are unreliable in real terms
Are very expensive
Once seen for what it is, all of the myriad confluence of solid state technology that everyday people are led to believe is what they need and want is on the whole quite a joke.
Any sane Technician in their right mind can see that this stuff is not working, is in fact making everything under the Sun much worse, and is colossal time waster.
All the best
SC
To Action Dave...
Unstable by nature
Are very expensive
All the best
SC
I'm all in. Sign me up. Do I get a badge or something? A cape, mask, and some tights?To Action Dave...
Unstable by nature
Are very expensive
All the best
SC
To Action Dave...
Unstable by nature
Are very expensive
All the best
SC
ELECTRICIAN SAID USING IN LINE "FAIR - RITES " TAKES THE PROBLEM AWAY
Yes, I have heard that clipping a ferrite core on the lines can help but I haven't tried it yet. You know like the ones you see often on computer cords.
I would not use just any piece of ferrite. Ge sent me some when I was having a problem. It worked in one case but not the other. Also you cannot use them on circuits that have lights that are dimmed.
What is the problem with using them on dimmer circuits?
I can see problems with circuits that carry RF signals piggybacked on the AC.
Tapatalk!
