PetrosA
- Lancaster, Pennsylvania
I got a call to check out why a recently installed (within the last year) generator won't work. It trips the breaker every time they try and run it to test it or when there's no power. It ran when the electrician who installed it tested it, so "somethin' musta happened since then."
The property includes a house made up of two double wides attached together and a large shop in the rear on one pole mounted 100A service, and a separate office building with a separate service. The generator is supposed to be able to run the house when the breakers are switched correctly.
I admit with shame that I didn't spot the issue right away although I did notice most of the other 50 issues. It took me about 5 minutes to realize what the problem with the generator was. I was stuck in a certain direction of thinking based on the claim that an electrician set this up. Evidently, the "electrician" who installed the generator hook-up is actually a real electrician who works for a local company and does mostly commercial work as a journeyman. He is presently wiring a local microbrewey. He hasn't charged the customer since he completed the installation.
His instructions to the customer were: Shut off the main breakers, start the generator, turn on the 50A breaker for the generator then turn on the house main. Poof. Generator breaker trips every time. Hmm.
Oh, and did I mention this is at a junkyard complete with a real junkyard dog and six inches of oily, toxic-waste type mud everywhere?
