Lizzy's Power Play
Hello everyone.
Customer purchased high end electric car. Every time they plug the car into the 240v. 50 amp receptacle in the garage to charge the car, the voltage level begins to drop. The voltage at the breaker and receptacle is a steady 240v., until you plug in the car and the voltage drops and fluctuates to about 229v. within 10 seconds. This causes the built in car charger to stop working.
Circuit is fed from a 100 amp sub-panel in detached garage. Detached garage service is not new, its fed overhead from the house panel with tri-plex. Ground rod may or may not exist.
Power Company checked voltage at meter and its 240v., until you plug in the car and it drops there also to 230v.
Car company techs are there and they can't find a problem with the car.
Any ideas. Thank-you.
