Importance of a ground access well?
greenspark1
New England
Hi all,
I have a client who is suggesting we use ground access wells with PVC around the ground rod. Since he's paying I'll design whatever he wants, but I would like to hear from all you knowledgeable people out there- what is the point of PVC pipe around the electrode? The well cover obviously gives you access to the ground rod for testing, but is there any other important/benefit to it? I typically do not use them (commercial 480V facilities) and have not had any trouble until now. Thanks for the info!
qcroanoke
Sometimes I don't know if I'm the boxer or the bag
Roanoke, VA.
Sorta retired........
Hi all,
As you said testing and inspection.
Cell sites are loaded with them.
don_resqcapt19
Illinois
retired electrician
It these are code required ground rods, you have to have at least 8' of the rod in contact with the earth. The exposed part of the rod in the well would not be in contact with the earth. If these rods are not required by the code, which is likely, then the code does not care how much earth contact they have, but the job specs probably do.
dereckbc
Plano, TX
I have done it for 35 years. I am in the telecom sector. It allows us to inspect the thermal welds, condition of the rods, test access point, and integrity. Quite common practice in my industry.
greenspark1
New England
Great, thanks for the replies everyone! I'm curious if anyone uses test wells or ever tests grounds for commercial, education, or similar facilities? The job spec is silent on this so always helpful to hear what's common practice in different industries. Sounds like cell towers certainly use them.
Good point.
dereckbc
Plano, TX
Unless those rods are 16 feet long. Another type with an access well is a Chemical Rod so you can add salt to them yearly.
Which would be perfectly fine if they were 10' rods. :)
And same would apply if the rod is not fully driven below grade - as in if you left the connection above grade to be able to inspect/test it easier for similar reasons.
